Search results for: 'SoftPLC+Robotics'
HVAC Alarming SL 2312000032$120.00The HVAC Alarming Library is a CODESYS library that reports states in five message classes via the CODESYS AlarmManager. Adding entries to the alarm list, removing them and preparing the message texts is handled by the library.
Also included in the HVAC Building & Process Automation SL package.
For more information: https://support.powerio.com/hub/codesys-hvac/hvac-alarming-library/description
Without license acquisition (download only), the HVAC Alarming SL operates for 30 minutes without functional limitations (Demo).
