Search results for: 'sizes and'
- size and
CODESYS V3 Intensive Training - Green Bay, WI - Jul 2026 2108100012-T-2026-07-13$2,750.00Available: 4 of 16Jul 13, 2026 (08:00 CDT) - Jul 16, 2026 (15:00 CDT)
1015 Lombardi Ave, Green Bay, WI 54304This 30-hour training is targeted for experienced control engineers transitioning to CODESYS, or for engineers wishing to take their knowledge of CODESYS to the next level. It combines basic and advanced training modules to give participants a comprehensive understanding of the capabilities of CODESYS, alternating between lectures and hands-on labs. It includes hints, tricks, and best practices compiled from many years of experience.
