This product is currently in the Service Phase, and its discontinuation has already been scheduled. We therefore recommend that you only use it for existing projects. Other solutions are available for new developments. We have compiled these for you on our website. Here you will also find the discontinuation dates for products in the Service Phase: Discontinuations
CODESYS UML
CODESYS UML allows to create the application in two languages, the UML class diagram and the UML state diagram.
CODESYS UML is part of the tool bundle CODESYS Professional Developer Edition.
