Search results for: 'network licenses'
- network license
- network license 108
- licenses manager 114
- licenses server 120
- licenses+server 120
- licenses codesys 190
CODESYS Automation Server On-Prem 250 2315000022 Subscription$8,988.00With the CODESYS Automation Server On-Prem 250 license, you connect up to 250 PLCs to your CODESYS Automation Server On-Prem. The license is offered as a one-year subscription and can be booked multiple times to connect additional PLCs.
CODESYS Automation Server On-Prem 100 2315000021 Subscription$3,595.00With the CODESYS Automation Server On-Prem 100 license, you connect up to 100 PLCs to your CODESYS Automation Server On-Prem. The license is offered as a one-year subscription and can be booked multiple times to connect additional PLCs.
CODESYS Automation Server On-Prem 25 2315000020 Subscription$899.00With the CODESYS Automation Server On-Prem 25 license, you connect up to 25 PLCs to your CODESYS Automation Server On-Prem. The license is offered as a one-year subscription and can be booked multiple times to connect additional PLCs.
- Unlimited Access
- Unlimited Access
