Search results for: 'plc'
- plc control 162
- plcs is 166
- plc is 166
- plcs+is 166
- plc server 150
HVAC Building Automation Package SL 2312000005$120.00 As low as $97.20The HVAC Building & Process Automation SL package contains field-tested function blocks and HTML5 visualization macros for building automation applications. It includes libraries for HVAC control, BACnet communication, Modbus integration, alarm management, and CSV data logging.The package is optimized for rapid engineering with the CFC editor and includes complete project templates for quick start development.For more information: https://support.powerio.com/hub/codesys-hvacWithout license acquisition (download only), the HVAC Building & Process Automation SL operates for 30 minutes without functional limitations (Demo).Learn More
