CODESYS Safe Control 4
Our application-based licence for functional safe PLCs offers you maximum flexibility and cost efficiency. The licence is based on the number of safe connections and allows up to 4 safe connections. Perfect for tailored safety in your automation system.
2306000001
From $107.00
  • Number of safe connections: max. 4
  • FSoE Master protocol
  • IEC 61131 standard library
