Search results for: '2305000013-F'
- 2304000013 f
HVAC I/O Modbus Modules 2312000001$0.00The library allows the use of HVAC Modbus I/O modules of the manufacturer powerIO via a RS485 COM port. The devices are appended in the project tree and are parameterized from there without further programming effort. In the I/O Mapping area the assignments of the input/output variables can be set. The modules are available with emergency manual operation level and without. The status of the manual override is queried.
