CODESYS Control Basic L
The application-based CODESYS Control Basic L license is specially designed for applications with up to two CANopen, Modbus, PROFIBUS or J1939 fieldbus instances. It contains 256 I/O channels and supports an application size of up to 3 MB and can be used on all Control SL products without restrictions.
2302000049
From $107.00
License Control Basic L
Metric
Basic M
Basic L
Standard S
EtherCAT/Profinet/EthernetIP
none
none
1 instance
CANopen/Profibus/Modbus/J1939
2 instances
2 instances
4 instances
Number I/O channels
128
256
512
Code size
1 MB
3 MB
3 MB
Visu S
Visu S
Visu S
Communication
Communication S
Communication S
Communication S
DataSource Manager
Yes
Yes
Yes
Dynamic Ansi C code
No
No
Yes
No
No
No
CODESYS Communication
CODESYS Visualization
Description of properties
Trial Operation
License check
Upgrade licenses
Application-based licenses can be combined with other store products, unless explicitly excluded. The I/O channels of additionally purchased fieldbuses are taken into account in the I/O channels license metric and are also counted.
  • Additional libraries are used: 3 MB code of license Basic L allow a lot of additional logic.
  • Additional logic to connect to the cloud: 5 MB code of license Standard M allows a very large application.
  • A lot of logic due to multiple monitoring and cloud connection: 6 MB code of license standard L allow very large applications
  • Mainly use of CODESYS libraries whose code size is not taken into account in the licensing: 3MB code of the Standard S licence is sufficient.
  • CODESYS Control Win SL
  • CODESYS Virtual Control SL
Updates
