CODESYS Control Basic M
The application-based CODESYS Control Basic M license is specially designed for applications with up to two CANopen, Modbus or J1939 fieldbus instances. It contains 128 I/O channels and can be used on all Control SL products without restrictions.
2302000048
From $83.00
License Control Basic M
Metric
Basic S
Basic M
Basic L
Fieldbus instances
0
2
2
Complex fieldbus instances
0
1
1
thereof host instances
0
0
0
0
1
1
Number of I/O channels
64
128
256
Visu S
Visu S
Visu S
Communication
Communication S
Communication S
Communication S
DataSource Manager
Yes
Yes
Yes
Dynamic C code
No
No
No
No
No
No
CODESYS Communication
CODESYS Visualization
Description of properties
Trial Operation
License check
Upgrade licenses
  • CODESYS Control Win SL
  • CODESYS Virtual Control SL
Updates
