Search results for: 'interface with plc'
- interfaces with plc
- plc control 153
- with to 154
- plcs is 158
- plc is 158
- plcs+is 158
CODESYS Virtual Safe Control SL 000139Safety without compromise: With CODESYS Virtual Safe Control SL, you get a certified SIL3 controller without any special hardware requirements. Install it on your commercial-of-the-shelf hardware and experience maximum safety - only with CODESYS.
CODESYS Sensor App for Android 000073$0.00With the product “CODESYS Sensor App for Android”, the sensor data of from an Android smartphone can be sent to a CODESYS controller.
HVAC I/O Modbus Modules 2312000001$0.00The library allows the use of HVAC Modbus I/O modules of the manufacturer powerIO via a RS485 COM port. The devices are appended in the project tree and are parameterized from there without further programming effort. In the I/O Mapping area the assignments of the input/output variables can be set. The modules are available with emergency manual operation level and without. The status of the manual override is queried.
