SQL4CODESYS 604100$0.00The framework āSQL4CODESYSā allows direct communication between CODESYS controls and databases. With the database, large amounts of data can be efficiently managed, which opens up many new possibilities (detailed logging of information, flexible production by retrieving production parameters, recording of process values during production for traceability, interface to ERP and order management systems, ā¦).
CODESYS SVN 2101000000CODESYS SVN enables an integrated connection to the software versioning system Apache⢠Subversion® for all application objects.
