Search results for: 'for and'
HVAC KNX SL 2312000023$120.00The HVAC KNX Library enables sending and receiving KNX group addresses via KNX IP interfaces (UDP) directly from the IEC program.It offers ready‑made function blocks for various DPT KNX data types and has been tested with various manufacturer‑specific KNX IP interfaces.For more information: https://support.powerio.com/codesys-hvac/hvac-knx-library/descriptionWithout license acquisition (download only), the HVAC KNX SL operates for 30 minutes without functional limitations (Demo).Learn More
