CODESYS Composer Module Developer
With the one-year Module Developer workstation license, one can develop modules for the composition in the CODESYS Application Composer.
2111000035
$72.00
Subscription Details
1 Year
26-11-2026
This license is intended for users of CODESYS Application Composer, the powerful development tool for creating large applications for modular machines from software modules created only once.
It is the appropriate license for an additional workplace specialized in developing module libraries, from which control applications for specific machines are created at other workplaces.
All Composer licenses allow the development of own modules. The Composer Module Developer license is tailored for module development: You can declare your own modules and test them in small test applications with max. 9 module instances, including unit testing. (Integration testing in realistic applications will require a full license.)
Subscription details:
Duration
  • The subscription includes one year of use of the CODESYS Application Composer in the corresponding performance class, starting from the date of purchase.
  • During this period, all features, updates and upgrades are included in the subscription.
Renewal of the subscription
  • Your subscription will automatically renew for another year if canceled later than 1 month before the subscription expires.
  • The automatic renewal is always one year, starting from the end of the previous subscription period.
  • To renew your subscription, we need valid credit card information. If your details are no longer valid, we will contact you by e-mail.
  • Once the renewal is complete, you will receive an email with information on how to renew your subscription.
Cancellation
  • Two months before your subscription expires, we will inform you automatically by e-mail about your cancellation option.
  • The cancellation period is 1 month to the end of the subscription period. You can cancel your subscription in your customer account.
  • If the subscription is not canceled 1 month before expiry, it will be renewed for another year.
  • Your subscription will be canceled by us if we do not have any valid credit card details or outstanding accounts at the end of the cancellation period.
  • A canceled subscription cannot be reactivated. A new subscription requires a new order.
At the end of the subscription period
After expiry of the subscription, the CODESYS Application Composer is only partially applicable.
No specific support information are available.
