Search results for: '2.3 codesys'
- 23 26 2 3 codesys
- 23 23 2 3 codesys
- Codesys project 200
- codesys party 200
- codesys product 201
- codesys products 201
- codesys third 200
CODESYS Automation Server On-Prem 25 2315000020 Subscription$899.00With the CODESYS Automation Server On-Prem 25 license, you connect up to 25 PLCs to your CODESYS Automation Server On-Prem. The license is offered as a one-year subscription and can be booked multiple times to connect additional PLCs.
- 1 license per 2 users
- Unlimited Access
- Unlimited Access
