CODESYS Visualization M
The application-based license CODESYS Visualization M enables a CODESYS visualization with up to 2048 data points. This can be displayed as a WebVisu, as a TargetVisu or both.
2304000011
$54.00
Performance classes
Number of tags
Visu S
128
Visu M
2048
Visu L
4096
Visu XL
8192
Visu XXL
unlimited
  • Integrated in the CODESYS Development System, for the development of the visualization/HMI
  • Development independently or together with the PLC application in a project
  • Scalable projects by enabling any number of usable tags
  • Simplified new creation of the application through guided project configuration
  • Access to data in the control network via data sources
  • Extensible library of elements from self-created visualizations with parameter interface
  • Loading of the visualization directly from the development environment to the controller
  • Display of all functions and elements available with CODESYS visualization, e.g.:
    • Alarm management
    • Trace and trend display
    • User management
    • Recipe management
    • Visualization styles
    • Multi-axiality
    • Integration of HTML5 Controls in the CODESYS WebVisu
Editor in CODESYS
V4.9.0.0 or higher
The Runtime Base License (ABL) must already be installed on the system. This includes the Visu S License.
Supported Platforms/Devices
Note: The target visualization requires a display at the device and graphic libraries in the firmware
