CODESYS Visualization L
The application-based license CODESYS Visualization M enables a CODESYS visualization with up to 4096 data points. This can be displayed as a WebVisu, as a TargetVisu or both.
Performance classes
Number of tags
Visu S
128
Visu M
2048
Visu L
4096
Visu XL
8192
Visu XXL
unlimited
Integrated in the CODESYS Development System, for the development of the visualization/HMI
Development independently or together with the PLC application in a project
Scalable projects by enabling any number of usable tags
Simplified new creation of the application through guided project configuration
Access to data in the control network via data sources
Extensible library of elements from self-created visualizations with parameter interface
Loading of the visualization directly from the development environment to the controller
Display of all functions and elements available with CODESYS visualization, e.g.:
Alarm management
Trace and trend display
User management
Recipe management
Visualization styles
Multi-axiality
Integration of HTML5 Controls in the CODESYS WebVisu
Editor in CODESYS
V4.9.0.0 or higher
The Runtime Base License (ABL) must already be installed on the system. This includes the Visu S License.
Supported Platforms/Devices
Note: The target visualization requires a display at the device and graphic libraries in the firmware
