Visualization Dialog Box
This example demonstrates how to work with dialog boxes in the visualization. The user can open a dialog box and enter some data. After closing the dialog box the data is stored and displayed in the main window.
000021
The visualization shows three variables which can be set via a dialog. The “Open Dialog” button will open a dialog box. There the values can be set and saved. Afterwards they are inserted into the main window.
