Visu Ladder Logic Editor
The ‘Visu Ladder Logic Editor’ allows direct programming on a PLC via the visualization.
This library contains a function block and a ladder logic editor which can be instanced by a PLC program. The function block has 8 inputs and 8 outputs and can be programed via ladder logic. An example shows the usage of the library.
