Visu Element XY Chart Example
This sample project demonstrates how to use the ‘XY Chart’ visualization element.
000103
The sample project ‘XYChartExamples’ includes three applications for the ‘XY Chart’ visualization element. This ‘XY Chart’ visualization element displays the curve of array values graphically as a line or bar chart in the Cartesian coordinate system.
The sample project includes applications covering the following topics:
  • Curve overlapping
  • Curve programming
  • Zooming and panning
