Upgrade of an already purchased application-based license (Base License) to the application-based license Standard L. The costs of the already purchased license (Base License) are fully credited.
CODESYS Control Win SL
CODESYS Control for Linux SL
CODESYS Control for PFC100 SL
CODESYS Control for PFC200 SL
DataSource Manager is not supported on Linux-based systems.
200 Cummings Center, Suite 272-D Beverly, MA 01915, USA
