Trace Example
The example “Trace Example” contains two applications concerning trace recording and trace configuration in IEC 61131-3 via the Trace Manager.
1.0.1.1
000044
The example project “TraceExample.project” shows how to record and store values of variables via the Trace Object and the Visu Trace Element. Another application demonstrates the configuration of a Trace Object in Structured Text.
More information on the Trace Object and the Visu Trace Element can be found in the CODESYS help:
CODESYS Development System > Reference, User Interface > Objects > Object ‘Trace’
and
CODESYS Visualization > Visualization Elements > ‘Special Controls’ > Element ‘Trace’ and its Dialogs
