Text Editor Example
The “Text Editor” example shows a visualization for editing, creating, and saving texts.
000105
With the sample project TextEditor.project included in the package, you can open, close, create, and save text files. By entering a text into the search field, corresponding words and lines can be found in a file. Moreover, a text field allows for writing and editing of texts, and the “ReadOnly” mode can be adapted by means of a switch.
