Softmotion Robotics HMI Example
The sample project ‘MotionHMI.project’ demonstrates some of the features available in SoftMotion Robotics. This project also includes a visualization and a Depictor object to visualize the movements. The project supports up to 6 axes.
Softmotion Robotics HMI Example with Companion Specification
The sample project ‘MotionHMI_Robot_Companion_Specification’ demonstrates an example implementation of the OPC UA Robot Companion Specification, with this the client application recives the specific data.
1.0.0.4
000108
With the sample project ‘SoftMotion Robotics HMI Example’, the users can configure an axis group (in the project) with any kinematics supported by CODESYS and control the axis group (from the visualization) either manually by jogging the axes or automatically by programming the movements. The robot’s movement can be visualized in 3D making use of the Depictor object configured inside the project. With the sample project ‘SoftMotion Robotics HMI Example Robot Companion Specification’ the client application is visualized with the help of an companion specification.
MotionHMI.project requires:
  • CODESYS Development System Version 3.5.16.0 or higher
  • Softmotion Version 4.3.1.0 or higher
  • Depictor Version 1.1.0.0 or higher
MotionHMI_Robot_Companion_Specification.project additional:
  • CODESYS Development System Version 3.5.18.0 or higher
  • CODESYS Visualization Version 4.1.0.0 or higher
  • CODESYS Communication Version 4.2.0.0 or higher
CODESYS Control V3.5.16.0 or higher MotionHMI_Robot_Companion_Specification.project requires: CODESYS Control V3.5.18.0 or higher
Platform and device-independent, according to the availability of the CODESYS Development System.
- Compatibility with CODESYS SoftMotion 4.16.0.0
- Fixed error in state machine of MotionHMI.project
28.05.2024
Improved example project MotionHMI_Robot_Companion_Specification.project
29.08.2022
New Features:
- Communication between two devices with OPC UA Robot Companion Specification
30.05.2022
New Features:
- Define custom coordinate systems
- Positions can be saved in the defined coordinate systems
- Jogging in the coordinate systems WCS and TCS
- Revised programming page (Simplified program editing + New program commands)
24.02.2021
