Serial COM Example
This example shows how to use the serial port. Therefore the communication of two ports with each other is implemented. The first one writes a string of characters, which is read by the second one.
1.0.0.2
000018
This example demonstrates how serial communication can be implemented, how ports are opened, closed and information is read and send. A second example shows the usage of the library SysCom.
