RPC Example
The package contains an example project for “Remote Procedure Calls”. Two applications demonstrate the implementation of server and client RPC applications.
1.0.0.1
000059
The example is based on the library RPC which is part of the CODESYS Development System. The library contains all required components for building RPC applications. The example project RPCExample.project shows the usage of this library on the basis of a simple client and server application.
