OPC UA Client Example
The example ‘OPCUAClient_Example’ demonstrates how to use the CODESYS OPC UA Client programmatically. It contains visualizations to access the applied functions via a user interface. The example ‘OPCUA_Datasource_Example’ demonstrates how a CODESYS OPC UA connection can be set up via data source manager.
