FB Visu Creator
The product “FB Visu Creator” is a plug-in which automatically creates visualizations from function blocks.
1.0.2.0
000055
The ‘FB Visu Creator’ plug-in automatically creates visualizations from function blocks. All desired function blocks and the input and output fields can be marked with attributes. The tool generates visualizations for the marked function blocks. Afterwards the visualization can be linked with an instance of the function block by a frame reference.
CODESYS Development System Version 3.5.8.0 or higher
CODESYS Control Version 3.5.8.0
All
Only function blocks of libraries and POU pools can be used to create visualizations.
  • Switch mode for input values
  • Bugfix for enum values
01.09.2021
Display enumeration values as text
29.09.2020
64 bit support
31.03.2020
- 07.08.2018
