The CODESYS Control Linux ARM SL is an adapted CODESYS runtime system for Linux/ARM-based platforms. The performance of the runtime system is almost arbitrarily scalable via the hardware properties of the system.
To install the product on the Linux OS via the CODESYS Development System, use the the included CODESYS Deploy Tool plug-in. After each restart the runtime system will be started automatically. If no valid full license can be found, CODESYS Control runs for two hours without functional limitations before shut down.
After installing the runtime environment, the PLCnext controller can be programmed as a PLC with the CODESYS Development System.
Benefits
The runtime system supports numerous I/O interfaces, such as discrete inputs and outputs or fieldbus adapters, as well as integrated IEC 61131-3 protocol stacks. The fieldbuses are configured directly in the CODESYS Development System without using any additional tools.
Communication with the CODESYS Development System for programming and debugging of the IEC 61131-3 application
Execution of controller functions and generation of graphical user interfaces
Interfaces
CODESYS OPC UA Server, extent of use depends on the application-based license used.
CODESYS WebVisu, extent of use depends on the application-based license used.
SL Extension
Integration of existing C code
Implementation of external functions
Support of start/stop switches
Usage of local I/Os
Use of external event tasks
Connect persistent memories (Retains
Fieldbus support
CODESYS CANopen Manager / Device
CODESYS EtherCAT Master
CODESYS EtherNet/IP Scanner / Adapter
CODESYS Modbus TCP Master / Slave
CODESYS Modbus Serial Master / Slave
CODESYS PROFIBUS Master
CODESYS PROFINET Controller / Device
Product options
CODESYS BACnet SL
CODESYS KNX SL
CODESYS Redundancy SL
CODESYS SoftMotion
CODESYS SoftMotion Light SL
CODESYS DNP3
OS: Debian-based Linux (32/64-bit)
CPU: ARMv7, ARMv8
Additional requirements
A SSH server must be running on the Linux system, to install the CODESYS runtime with the CODESYS Development System.
Dynamic libraries needed by the CODESYS Control Runtime binary:
libm.so.6
libpthread.so.0
libdl.so.2
librt.so.1
libc.so.6
libgcc_s.so.1
Third-party requirements: - libc >= 2.27 (2.38 on ARM32) (required by CodeMeter Runtime)
Other Linux distributions may also be used at your discretion but are not part of the product release and related tests.
