Element Collections Examples
The CODESYS package “Element Collections Examples” contains sample projects for using the library “Element Collections” library.
1.0.0.1
000095
The CODESYS library “Element Collections” contains function blocks for lists, queues, stacks, and hash tables. The elements of collections are instances of function blocks of type IElement. The sample project “Element Collections Examples” demonstrates how to use individual components.
