Upgrade to CODESYS Safe Control L
Our application-based licence for functional safe PLCs offers you maximum flexibility and cost efficiency. The licence is based on the number of safe connections and allows up to 64 safe connections. Perfect for tailored safety in your automation system.
2306000004
$448.50
Number of safe connections: max. 64
