CODESYS Redundancy SL makes it possible to run one and the same IEC 61131-3 application on two independent soft PLC systems at the same time. If a control fails, the passive control is activated. The function enables the mutual monitoring and synchronization of two controllers.
The redundant cross-connection between the two controllers is implemented using a TCP/UDP-based protocol. The active controller controls the I/O system, while the passive controller monitors the active controller and synchronizes itself with it. When the redundant system is started up, the first PLC started goes into the “standalone” state until the second PLC is started and synchronized. Then the first changes to the active state, the second to the passive state (standby). If a control fails, there is an automatic switchover.
A manual switchover can be initiated via a function interface. The boot application and the memory are updated automatically. IEC timers are synchronized in each task cycle.
CODESYS Development System Version 3.5.17.10 or higher
CODESYS Control V4.1.0.0 or higher
CODESYS Control V3.5.17.10 or higher
CODESYS SoftPLC systems (not for embedded devices)
Two SoftPLC systems of the same type in the same version
TCP / IP stack
The synchronization is limited to one task.
IEC timers are locked during the execution of a task.
During the synchronization phase, the application data are copied between two cycles.
Pointers and other system resources must be stored locally on the respective device.
