The CODESYS Communication M license enables the use of the Symbol Configuration, Communication Manager and Datasource Manager. The exchange of up to 4096 tags is allowed.
The publishing of data is done via OPC UA. Two use cases are supported for this:
Variables of an application can be published by directly selecting them without having to define a specific information model.
The usage of OPC UA Information Models. The support is implemented in a generic way. The object- and data types defined in information models can be converted to IEC data type declarations.
Receiving data is achieved by using data sources. The source can either be another CODESYS application or an OPC UA Server.
The CODESYS Communication S license is already included in the runtime system license by default.
CODESYS Development System V3.5.19.10 or higher CODESYS Communication V4.3.0.0 or higher
CODESYS Control V3.5.19.10 or higher
Supported Platforms/Devices
Note: In demo mode (no license for runtime and OPC UA), the software runs for two hours without a license. After that, a manual restart is required.
200 Cummings Center, Suite 272-D Beverly, MA 01915, USA
