CODESYS OPC DA Server SL Demo
The CODESYS OPC DA Server SL enables direct OPC DA communication with all CODESYS programmable controllers.
(A 30-day demo license is available for testing).
3.5.21.0
2302000028
The OPC DA Server is able to communicate with both, V3 as well as V2.3 PLCs, at the same time. Furthermore a missing PLC can be simulated. Then a symbol file with all symbols instead of the PLC provides the OPC DA server the symbol pool (XML file or SDB file).
A detailed description of all functionalities and commissioning can be found in the CODESYS OPC DA user guide (part of the setup).
CODESYS Development System V3 or V2.3
CODESYS Control V3 oder V2.3
Windows 8/10
OPCConfig (part of the setup)
Note: A 30-day demo license is available for this product.
- 18.03.2025
- 22.04.2025
- 23.01.2025
- 20.11.2024
- 23.09.2024
- 31.07.2024
- 04.06.2024
- 19.03.2024
- 02.05.2024
- 06.02.2024
- 04.12.2023
- 23.10.2023
05.10.2023
- 03.08.2023
- 01.06.2023
- 09.03.2023
19.09.2019
- 29.07.2019
23.08.2019
17.12.2018
18.01.2019
- 23.08.2018
- 10.07.2018
13.11.2018
- 20.12.2017
- 16.02.2018
