CODESYS LicenseServer for Linux SL
Licensing made easy - CODESYS License Server for Linux allows users to set up a network license server on Linux devices and apply licenses via a web-based management tool.
4.14.0.0
000137
The CODESYS LicenseServer for Linux package allows you to conveniently set up a license server on a Linux-based device and apply licenses to it. The network license server can be used to centrally license CODESYS controllers in the entire network.
Deployment is carried out conveniently via the CODESYS Development System. A network-compatible version of Wibu Codemeter Runtime is installed on the target system. In order to be able to use the network license server, a plugin for Redhat Cockpit is also supplied, which allows users to activate application-based licenses on the server via a browser.
Engineering
CODESYS Development System V3.5.20.10 or higher
Runtime
CODESYS Virtual Control SL V4.12.0.0 or higher
Supported Platforms
Debian Linux
- 03.12.2024
- 29.08.2024
- 03.07.2024
