CODESYS in Building Automation Examples
This package contains the examples from the video series “CODESYS in Building Automation” (https://www.codesys.com/industries/building-automation.html).
000111
The sample projects demonstrate a selection of CODESYS features that are important in the field of building automation. Samples include:
  • Programming in ST/CFC
  • Integrated visualization
  • BACnet
  • OPC UA
  • KNX
  • Modbus
  • CANopen
  • Network variables
  • Application Composer
We recommend working through the examples by following the video series “CODESYS in Building Automation”.
Development system
CODESYS Development System V3.5.14.0 or later
Runtime
CODESYS Control V3.5.14.0 or later
Note: Use the “Device Reader” project for locating the functions supported by the PLC. The “Device Reader” project is available in the CODESYS Store free of charge.
Additional requirements
Activation of the runtime components “CmpBACnet” and “CmpKNX” in the configuration file
Required accessories
Version Release Notes
Release Date
- 27.08.2019
