The CODESYS EtherNet/IP Adapter SL is not compatible with application-based licenses.
The CODESYS EtherNet/IP Adapter is an add-on for CODESYS compatible PLCs. By means of standard Ethernet ports, these devices are converted into EtherNet/IP adapters. The bus is configured directly from within the CODESYS Development System. Devices that are configured in this way exchange Ethernet messages with interconnected EtherNet/IP scanners.
2303000006
$120.00
A specific EtherNet/IP configurator is already integrated in the standard setup of the CODESYS Development System. To use this, the user requires a license, which is either already stored in the target system 1 or can be added later 2. In addition, a protocol stack is required for implementing the EtherNet/IP communication on the configured Ethernet port. This stack is supplied with the license as a CODESYS library.
If the CODESYS EtherNet/IP Adapter is licensed on the device to be programmed, then it can communicate with connected scanners and operate EtherNet/IP modules. All parameters for communication are predefined in the configurator. An adapter-EDS-file is included in the standard delivery.
Configurator
Editors
  • Ethernet Bus Editor
  • EtherNet/IP Adapter Editor
  • EtherNet/IP Module Editor
Communication Settings
  • IP Address
  • Device Identification (Vendor ID, Product Code, …)
  • I/O Data Data Layout (module configuration)
Creation of custom assembly layout
supported
Valdidation of configuration
supported
Diagnosis
  • Display of device state
  • Display of connection errors on status page
EDS Export
Export of an EDS file suitable for the configuration.
IEC Stack
Supported Platforms
  • 32/64 bit
  • Little/Big Endian
Specification
CIP Networks Library Volume 1 and 2
max. Number of Connections
no restriction
max. Number of Input/Output Assemblies
No restriction;
The supplied EDS files support only one Input and Output Assembly by default.
But this can be extended by creating own corresponding EDS files.
In this way, I/Os can be distributed over several Assemblies/Connections.
Configuration Assembly
not supported
Connection Types
  • Class 1 (I/O Messaging)
  • Class 3 (Explicit Messaging)
  • UCMM
I/O Connection Types
  • Point to Point and Multicast
  • Cyclic Transmission
  • Exclusive Owner, Listen Only, Input Only
  • Tag based connections (one Tag per connection)
Minimal RPI
1 ms
Supported Objects
  • Identity Object (16#1)
  • Message Router Object (16#2)
  • Assembly Object (16#4)
  • Connection Manager Object (16#6)
  • QoS Objekt (16#48)
  • TCP/IP Interface Object (16#F5)
  • EtherNet Link Object (16#F6)
  • LLDP Management Object (16#109)
Large ForwardOpen
supported
LLDP
only transmission supported
CIP Motion
not supported
CIP Sync
not supported
Device Level Ring (DLR)
not supported
ACD
supported, deactivated by default
Conformance
tested with CT21 test tool and CODESYS EtherNet/IP V4.8.0.0 on:
CODESYS Control for Raspberry Pi SL V4.16.0.0 and CODESYS Control RTE 3.5.21.10
API
Diagnosis
  • State and Diagnosis variables
  • Ethernet Status Informationen
  • Generic Device Diagnose
Reconfigure
supported
other functionalities
  • Reset of adapter
  • Registration of own CIP Objects
1
Device manufacturers can equip their products with CODESYS EtherNet/IP Adapter and license them in advance. The use license is already included in SoftPLC systems from 3S-Smart Software Solutions (for example, CODESYS Control Win and CODESYS Control for Raspberry Pi).
2
End users can extend single, compatible devices with CODESYS EtherNet/IP Adapter SL. The license is saved on a special device dongle (CODESYS Key) or software license container (Soft Key) on the device.
  • CODESYS Control runtime system on the device with SysSocket, SysEthernet and SysFile component.
  • Available Ethernet port on the device
  • WIBU Codemeter support
CT19.1 compliance requires runtime version 3.5.19.0 or newer for some operating systems (e.g. Windows, VxWorks).
