CAA Device Diagnosis Example
This sample project demonstrates how to use the ‘CAA Device Diagnosis’ library for generic diagnostics for devices available in the project.
1.0.0.1
000085
The example use cases demonstrate how to use the ‘CAA Device Diagnosis’ library for the following:
  • Starting, stopping, and resetting devices
  • Activating and deactivating devices
  • Traversing the device tree
  • Collecting device and bus information
