AC Module Teaching Example
Library and project for creating and using learnable modules by means of simple lighting controls.
000066
The Application Composer provides the option of a modular configuration of an application. When the structure is defined one time in the module tree, a static IEC application is generated from it. This means that the modules are connected directly with their submodules and cannot be modified at runtime.
This example demonstrates how to create a dynamic configuration from a pool of separate modules at runtime.
In addition, this configuration should be stored persistently so that the last set configuration can be downloaded each time the application is restarted again.
Programming System CODESYS Development System V3.5.5.0
Runtime System CODESYS Control V3.5.5.0
All
Additional Requirements -
Restrictions -
Licensing Free of charge
Required Accessories Applicaton Composer
Version Release Notes
Release Date
- 07.08.2018
