XML Utility
1.0.1.2
2111000008
The library “XML Utility” contains function blocks to read and write xml files or xml strings on a control.
The library “XML Utility” is now part of the product IIoT Libraries SL and is no longer available as single product.
The library ‚XML Utility‘ contains function blocks to read and write xml files or xml strings on a control. All elements of the xml file are stored in an array of structures. The library also contains function blocks to find elements by name and attribute. The usage of the library is demonstrated by two example applications.
The library contains following components:
  • IEC 61131-3 library XMLUtility (Namespace XML)
  • Example project XMLUtilityExample.project
  • Integrated CHM programming reference
  • Product data sheet (de und en)
CODESYS Control V3.5.14.0
All
Workstation license
CODESYS Security Key for CODESYS < 3.5.14.0
A list of alternative support resources can be found at the support section of the CODESYS North America page.
Version Release Notes
Release Date
Bugfixes/Improvements:
  • Trimmed attribute names
  • ‘/’ in attribute values are now allowed
03.07.2019
New Features:
  • The XML declaration can now be disabled.
15.02.2019
New Features:
  • Licensing without dongle
  • Performance tuning
  • Bugfixes
19.12.2018
New Features:
  • Support of xml data arrays
27.07.2018
New Features:
  • Implementation of asynchronous calls
  • Optimized error handling
  • Bug fixes
23.02.2018
Removed obsolete libraries (CAA Generic List and Tree Factory etc.) 08.01.2016
Support of Power PC runtime systems. 16.06.2015
This version fixes a problem with utf 8 coded special characters. 02.06.2015
Improved documentation 20.01.2015
Support of 64 bit controls. 19.09.2014
  04.08.2014
Reviews
Write Your Own Review
