Visu Demo Overlay
The software package “Visu Demo Overlay” includes a sample project which shows and uses the feature overlay for the webvisualization.
000122
Example:
In the projects, the features of overlay are used: * Overlay of NativeControls (e.g. Browser/Camera) * Smooth animation done in the client
The project shows a system control in a short form. Focus is on the animation of dialogs and the menu.
CODESYS Development System Version 3.5.16.10 or higher
CODESYS Control V3.5.16.0 or higher
All devices with support of webvisualisation
Exampleapplication is only for the webvisualization
Starting with Version 3.5.17.0 also for Windows-Targetvisualization and Linux-Targetvisualization with support by the device.
A list of alternative support resources can be found at the support section of the CODESYS North America page.
Reviews
Write Your Own Review
