SNTP Service
2111000009
The library SNTP Service contains function blocks for time requests and time setting via SNTP.
The library “SNTP Service” is now part of the product IIoT Libraries SL and is no longer available as single product.
Workstation License
The library SNTP Service contains function blocks for easy implementation of SNTP client and server components on a CODESYS control (SNTP V3, SNTP V4). The function block SNTPGetUTCTime can be used to request the UTC time of a SNTP/NTP server. The function block SNTPServer can be used to build a simple SNTP server.
Function blocks (FBs) of the SNTP library:
  • SNTPGetUTCTime: FB to request the time of a SNTP server (SNTP client)
  • SNTPServer: FB to send the local server time (SNTP server)
CODESYS Development System V3.5.14.0 or higher
CODESYS Control V3.5.6.0
All
  • Only SNTP unicast mode is supported
  • Unencrypted messages (without Autokey Cryptography)
  • IP V6 is not supported
Reviews
Write Your Own Review
