Serial COM with Visualization
1.0.0.1
000025
This example shows the use of three COM Ports. One port is for reading, another for writing and one can do both. The included visualization shows the reading and writing result together with the used parameters. The user can switch between the three different ports.
This example includes the communication with a serial COM port. In the visualization can be decided if one port should be used for both reading and writing or if two ports, one for reading and one for writing should be used.
Reviews
Write Your Own Review
