CODESYS X-MasTweet
000087
CODESYS X-MasTweet is a CODESYS sample application – appropriate for the Christmas season. The application sends encrypted messages to Twitter with the help of a sample library from the CODESYS Store. The project uses encrypted communication by means of an X.509 certificate that is available in CODESYS V3.5 SP10 and later.
Tweet your Christmas greetings! This requires a CODESYS-compatible controller with Internet access, for example the demo version of the SoftPLC CODESYS Control Win that is included in the CODESYS setup.
Install the CODESYS X-MasTweet package into the CODESYS Development System, open the included CODESYS project, and download it to the target device. You are provided with a user interface for operating the application, either directly in the CODESYS Development System, or from a CODESYS TargetVisu on the device screen where you downloaded the application. Furthermore, the linked Twitter account can be viewed independent of the CODESYS visualization in a browser at https://twitter.com/CODESYS_XMAS.
With the package, the Twitter library (a sample library for using the Twitter API) is installed to the library repository of the CODESYS Development System. It includes the use of encrypted communication options based on X.509 certificates.
Caution: The sent messages are public. Please exclude any personal information.
Programming system
CODESYS Development System V3.5.10.0 or later
Runtime system
CODESYS Control V3.5.10.0 or later
Note: Use the “Device Reader” product for locating the functions (licenses) supported by the PLC. The product is available in the CODESYS Store free of charge.
Additional requirements
Internet access for PLC or SoftPLC
Required accessories
Provider
All Versions
No version information available.
Reviews
Write Your Own Review
