CODESYS SoftMotion CNC+Robotics SL
$120.00
4.7.0.0
2305000001
  • Buy 4 for $114.00 each and save 5%
  • Buy 10 for $109.20 each and save 9%
  • Buy 25 for $102.00 each and save 15%
  • Buy 50 for $97.20 each and save 19%
CODESYS SoftMotion CNC+Robotics is an additional option for CODESYS compatible SoftPLC systems. CODESYS SoftMotion CNC+Robotics extends the functional scope of these systems from a purely logical controller to a CNC motion controller with 3D interpolation, as well as to a controller platform for robots with defined kinematic axis groups.
CODESYS SoftMotion CNC+Robotics enables the control of coordinated, spatial CNC and robotic motion on qualified CODESYS compatible SoftPLC systems.
Functional principle:
  • Project engineering of motion using function library modules
  • Configuration of actuated drives with fieldbus support integrated in the CODESYS Development System
  • Decoupling of application creation from the applied hardware by abstracting the drives with drive group names in the device tree
  • Integrated motion planning:
Typical applications of CODESYS SoftMotion CNC+Robotics:
  • As an additional option for powerful, CODESYS compatible control systems with strict real-time behavior (FPU recommended)
  • Learned CNC motion with modifications by the end user (for example, in metal and woodworking machines)
CODESYS Development System V3.5.9.50 or higher
CODESYS Control Version 3.5.5.0 or higher
All supported by CODESYS:
  • Devices with integrated fieldbus (EtherCAT, CAN/CANopen, or Sercos)
WIBU Codemeter Support
CODESYS SoftMotion CNC+Robotics requires CODESYS SoftMotion as a basis license.
License activation optional on CODESYS Key or Soft Key (Soft Key: free of charge component of CODESYS Controls)
Provider
All Versions
Version Release Notes
Release date
Release Note
CODESYS SoftMotion 4.7.0.0 brings buffer modes to the single axis and master slave function blocks. Additionally, many bugs have been fixed.
New Features
  • [SM-2068] BufferMode for Part 1 function blocks
  • [SM-2333] Robotics: new polar kinematics with z-axis
Major bug-fixes
Only bugs not patched in version 4.6.2.0 or 4.6.3.0 are listed.
  • [SM-2364] Exception when fEditorSlaveMin is set for “0” (CAM_TABLE_INVALID_SLAVE_MINMAX)
  • [SM-2418] Atomic_SRSW_W: Read method returns inconsistent values
  • [SM-2457] CPTR: Assertion in SMC_MotionKernel_CPTR.GetPose after MC_GroupInterrupt
  • [SM-2513] MC_CamIn: Potential AccessViolation if more than three tappets are used in parallel
  • [SM-2515] MC_MoveSuperimposed: jump in axis position if the underlying movement changes the owner and the aborting FB is called before MC_MoveSuperimposed
  • [SM-2521] SML_Drive_ETC: readSDO/writeSDO function block needs to be called with xExecute=FALSE after successful completion
  • [SM-2524] CNC: Interpreter stack overflow if subprogram uses local variables
  • [SM-2530] SMC_MoveContinuousAbsolute/Relative may reach end velocity at wrong position (ramp type trapez, acceleration <> deceleration)
  • [SM-2531] MC_MoveAbsolute / MC_MoveRelative + MC_MoveSuperimposed: possible jump in set position if superimposed movement finished one cycle before underlying movement
33 minor Bugs have been fixed.
Supported drives
  • [SM-2234] New driver for Delta ASDA A3 / B3 drive
Compatibility Information
General
This version is compatible with CODESYS V3.5 SP9 Patch 5 and newer. However we recommend the newest patch level of CODESYS V3.5 SP15. Using axis groups in simulation-mode requires compiler version 3.5.10.40 or later.
  • [SM-2364] Exception when fEditorSlaveMin is set for “0” (CAM_TABLE_INVALID_SLAVE_MINMAX). MC_CamTableSelect now fails with ErrorID
    • SMC_CAM_TABLE_INVALID_MASTER_MINMAX, if in the passed CamTable fEditorMasterMax <= fEditorMasterMin or fTableMasterMax <= fTableMasterMin.
    • SMC_CAM_TABLE_INVALID_SLAVE_MINMAX, if in the passed CamTable fEditorSlaveMax <= fEditorSlaveMin or fTableSlaveMax <= fTableSlaveMin.
  • [SM-2422] Compatibility: changes in project if the SM package is increased to 4.6.1.0. Logging in to an application downloaded with SoftMotion 4.6.1.0 installed may require an online change when logging in with SoftMotion 4.7.0.0.
Known Limitations
  • [SM-2314] MC_GroupStop/MC_GroupHalt, CP: immediate braking with given dynamic limits. MC_GroupHalt of CP movements cannot be aborted. A subsequent movement is always treated as buffered.
  • [SM-1901] ETC Drives using modular slaves not working with CODESYS SP13 and SP14 if SlotIndexIncrement is not 0. The mapping of drive objects in the Scaling/Mapping page of SoftMotion drives is computed incorrectly for some EtherCAT slaves and CODESYS versions. This happens if (and only if) all of the following conditions are met:
    • The slave is a multi axis slave, and
    • the slave uses modules, and
    • the attribute SlotIndexIncrement (in the ESI file) of the axis modules is not 0, and
    • the CODESYS version is below 3.5.15.0.
Not released / Not tested
  • Device Application Support. The usage of axis groups in child applications is not supported. See SM-847. Not released.
28.05.2020
Release Note
CODESYS SoftMotion 4.6.3.0 is a bug-fix release. It fixes a major bug in the SMC_GroupJog2 function block.
  • [SM-2480] SMC_GroupJog2: Jogging with ABC_as_ACS does not work correctly
  • [SM-2479] SMC_GroupJog2: possible error “SMC_CP_INVALID_PATH_ELEM” if orientation mode Axis is used
General
Known Limitations
16.03.2020
Release Note
CODESYS SoftMotion 4.6.2.0 is a bug-fix release.
  • [SM-2429] Compatibility: changes in project if the SM package is increased to 4.6.1.0
  • [SM-2430] Axis limit violation on Pick&Place without stop
  • [SM-2431] Problems with CartBlending elements with vanishing axis derivatives: performance degradation and numerical difficulties
  • [SM-2438] MC_GroupInterrupt, CP: Interrupt might not finish if commanded just before the end of a segment
  • [SM-2440] Possible error SMC_CP_INTERNAL_EVAL_CACHE_ERROR on override
  • [SM-2442] Acceleration Limit violation during blending (U-Pick)
General
  • [SM-2429] Compatibility: changes in project if the SM package is increased to 4.6.1.0. Logging into an application downloaded with SoftMotion 4.6.1.0 installed may require an online change when logging in with SoftMotion 4.6.2.0.
Known Limitations
24.02.2020
Release Note
CODESYS SoftMotion 4.6.1.0 is a feature and bug-fix release.
Major bug-fixes
  • [SM-2015] Project environment: Update of SoftMotion profile without installed device description leads to missing SoftMotion libraries
  • [SM-2260] CP, Resume after error: Null reference exception if resume after error is enabled and an error occurs before any movement was planned
  • [SM-2288] AXIS_REF_SM3: Axis generates an error when setting no control mode while moving
  • [SM-2315] Parker PSD: Change the device IDs to fit the previous versions
  • [SM-2340] CNC: The H points are lost for G Codes of Length 0 and if the End Velocity of the previous GCode is 0
  • [SM-2350, SM-2355] Check of Axis Limits fails when a PTP_PI aborts a PTP_FAST mvt and if the IpoState is end_of_path and fIpoTime is 0
36 minor bugs have been fixed.
New Features
  • [SM-1304] Robotics: Support for 6D tools
  • [SM-2247] Robotics: make it possible to resume after MC_GroupHalt/MC_GroupStop
  • [SM-2152] Improve CP-Tracking for Pick&Place applications step 1
Improvements
  • [SM-2183] AXIS_REF_MAPPING_SM3: new setting to enable writing of outputs in application stop
  • [SM-2192] SMC_GroupJog2: handle huge distances better
  • [SM-2222] Robotics: Improve CP kernel on multicore
  • [SM-2269] Orientation mode axis: don’t create an error if orientation mode axis is used on a kinematics without any orientation DOF
  • [SM-2299] Support mapping of I/O Parameters of type BIT
Supported drives
  • [SM-638, SM-1191, SM-2305] Driver for Beckhoff EL7031 stepper module
  • [SM-2229] Yaskawa: Integrate Sigma-7 400V double axis
  • [SM-2215] SM3_Drive_ETC_KEB_H6: make it possible to immediately disable from state quick stop, even if _bImmediateDisabling is FALSE
  • [SM-2233] SM3_Drive_ETC_KEB_H6: consider voltage enabled, ignore operation enabled
  • [SM-2273] Festo CMMP-AS - remove startparameter sw limits
General
Issues from version 4.6.1.0
  • [SM-2314] MC_GroupStop/MC_GroupHalt, CP: immediate braking with given dynamic limits. MC_GroupStop/MC_GroupHalt now require the commanded dynamics to be valid. This means that the values of the inputs Deceleration and Jerk have to be positive and the values of the inputs AccFactor and JerkFactor have to be in the range ]0, 1]. An invalid value on any of these inputs leads to an error stop. If you update an application to this SoftMotion version, please make sure that all calls to MC_GroupStop/MC_GroupHalt in your application have valid inputs.
Issues from version 4.6.0.0
  • [SM-2067] Infranor Xtrapuls: it is not possible to access the high 16 bit of the digital inputs and digital outputs Infranor Xtrapuls: The member variables wDigitalInputs and wDigitalOutputs of the SoftMotion axes are now of type DWORD instead of WORD. Updating these devices in existing projects can lead to new compile errors, if wDigitalInputs or wDigitalOutputs were assigned to WORD variables.
  • [SM-2080] U-Pick: improve smoothness to reach more picks per minute: Blending between path elements has been improved to enable faster and smoother pick&place operation. In particular, consecutive lines are now blended even if their direction is exactly opposite to each other (e.g. the down-movement followed by the up-movement of a typical pick&place cycle). To restore the behavior of SoftMotion versions before 4.6.0.0, set the flag bCPCompositeBlending of the structure SMC_AXIS_GROUP_COMPATIBILITY_OPTIONS to FALSE (input of MC_GroupEnable). Note: this change only affects non-tracking movements.
  • [SM-2191] Robotics: change default planning interval to 16 ms: The default for the robotics planning interval has been changed to 16 ms. The planning interval is an internal parameter of the robotics trajectory planner. The value determines the accuracy of the trajectory and the performance requirements of the planning algorithm. (Larger planning intervals lead to reduced performance requirements.) In earlier versions of CODESYS SoftMotion, the default for the planning interval was twice the bus task interval, but at least 4 ms. The planning interval can be changed using SMC_TuneCPKernel.
Known Limitations
20.01.2020
Release Note
CODESYS SoftMotion 4.6.0.0 is a feature and bug-fix release.
Major bug-fixes
  • [SM-2116] SM: AutoMoveGantry: axis limit violation
  • [SM-2146] AxisGroup: Enable AxisGroup implicit code creation
24 minor bugs have been fixed.
Improvements
  • [SM-106] SM: AXIS_REF_ETC: make it possible to access the EtherCAT slave
  • [SM-644, SM-1236] SM_Drive_PosControl: it should be possible to adjust the parameters online by the iec application
  • [SM-1973] When controller mode “nocontrol” is set, the SoftMotion driver will not write the cyclic outputs of the drive
  • [SM-2016] Robotics: allow to resume the programmed path after an error
  • [SM-2190] Scaling: new scaling view for linear motors
  • [SM-2097] Robotics: improve blending if tangent and curvature matches
  • [SM-2211] Brake Control FB: Create a new Parameter to get the brake state
Supported drives
  • [SM-1967] CMZ LBD
  • [SM-2119] Updated driver for Panasonic MINAS A5B and MINAS A6B
  • [SM-2166] Updated driver for new firmware of Parker PSD
General
Known Limitations
09.09.2019
Release Note
CODESYS SoftMotion 4.5.1.0 is a patch release.
Major bug-fixes
  • [SM-2028] Path Invariant PTP: Deceleration is too high while blending
  • [SM-1979] Interaction AxisGroup/CP-Kernel: Reset may be ignored
  • [SM-2094] Path-invariant PTP: If cartesian position and orientation of dest is close to start, PTP_PI is not executed and assertion fails
  • [SM-2056] CP-Tracking: the axis group should be able to follow the PCS after starting the CP-Tracking kernel with a new movement
  • [SM-2112] CP-Tracking: Movement not finished
  • [SM-2117] CP-Tracking: Interrupt: possible null pointer exception
  • [SM-2126] MC_GroupContinue: possible error SMC_CP_ROTARY_AXIS_RANGE_VIOLATION
19 minor bugs have been fixed.
Improvements
  • [SM-1931, SM-2037, SM-1919, SM-2026] Support for multicore (CNC path task and robotics planning task may now be safely put to a different core)
  • [SM-1281] Robotics, Jogging: Enable path accurate jogging
  • [SM-1928] CNC_Visu: SMC_PathCopierFile should be able to deal with subprograms
New supported drive
  • [SM-2065] New driver for Hitachi ADV series (EtherCAT)
  • [SM-655] CMZ IBD EtherCAT/CANopen firmware update to version 30
General
This version is compatible with CODESYS V3.5 SP9 Patch 5 and newer. However we recommend the newest patch level of CODESYS V3.5 SP14. Using axis groups in simulation-mode requires compiler version 3.5.10.40 or later.
Issues from version 4.5.0.0
  • [SM-668] Kin_Scara2_Z / Kin_Scara3_Z : dealing with (0/0). A change in behavior has been introduced in the following case: A scara robot is used, with equal lengths of arm 1 and arm 2, and a PTP movement is commanded to cartesian position (X=0, Y=0) (in MCS). Previously, the first axis (a0) would move to 0°. Now, the first axis will keep the value it had at the start of the movement. Background: The position (X=0, Y=0) can be reached by the scara robot in different axis positions. a1 needs to be 180° (or -180°), a0 can have an arbitrary angle. To resolve this ambiguity, we now choose the angle for a0 that it had at the start of the movement. This is consistent with the behavior of other transformations.
  • [SM-1820] Kin_Wrist3: Range of third axis violated. If the software position limits of the corresponding axis are deactivated, then Kin_Wrist3 is supposed to keep the values of its third axis inside [0; 360]. In contrast to previous versions, this works properly now. This affects Kin_ArticulatedRobot_6DOF, too, as Kin_Wrist3 is its tool kinematics.
Known Limitations
  • [SM-1901] ETC Drives using modular slaves not working with CODESYS SP13 and newer if SlotIndexIncrement is not 0. SoftMotion drives below modular EtherCAT slaves do not correctly determine the I/O mapping if the attribute “SlotIndexIncrement” in the ESI files of the slaves is not zero. Only affects CODESYS versions SP13 and newer. As a workaround, the I/O mapping may be entered manually in the Scaling/Mapping page of the SoftMotion drive.
  • ETC KEB H6 Dual. Due to problems with the test hardware, the driver could not be tested. Not tested.
06.05.2019
Release Note
CODESYS SoftMotion 4.5.0.1 is a hotfix release that fixes the following major bugs:
  • [SM-2062] PTP: Uninitialized variable leads to strange movements (accident introduced in 4.5.0.0)
  • [SM-2050] MC_TrackConveyorBelt: possible jump of PCS if belt is controlled by a modulo drive
  • [SM-2063] Kin_Staubli_TX60_Pos_RRR: error in Initializer, parameter d4 is assigned value of parameter d3 (accident introduced in 4.4.0.0)
  • [SM-2049] CP-Tracking: possible error SMC_CP_TRANSITION_NOT_SMOOTH when blending between different PCS with bImprovedSymmetricBlending
  • [SM-2052] CP-Tracking: when blending from different motion type (e.g. different PCS), creation of orientation blending may fail
General
Known Limitations
  • [SM-2028] Path Invariant PTP: Deceleration is too high while blending. Blending between movements commanded with MC_MoveDirectAbsolute/Relative and other movements decelerates too much, if the movement type “Path_Invariant” is used. The movement type “Fast” is not affected. This problem already affects version 4.4.0.0, where the movement type “Path_Invariant” has been introduced.
  • Multicore Support: All SoftMotion tasks must run on the same core. See SM-1155 and SM-1005. Not released.
08.04.2019
CODESYS SoftMotion 4.5.0.0 is a quality and bug-fix release. Test coverage has been substantially extended and many problems have been fixed.
Improved blending
  • [SM-1936] Improved blending elements and more accurate planning leads to improved blending when using MC_MoveLinearAbsolute/Relative and MC_MoveCircularAbsolute/Relative.
  • [SM-1775] Better blending at the beginning of a movement-sequence. Trajectory planning is delayed if the second movement of a sequence is not commanded in the same cycle of the bus task. This enables full blending of, for example, a pick and place sequence.
Other improvements
  • [SM-1280] Allow an axis range of more than 360° for axis 1 and 4 of the 6-axis articulated robot (Kin_ArticulatedRobot_6DOF).
  • [SM-1857] Buffered PTP movements (MovementType “Fast”) now show the exact target position of the movement for at least one cycle.
  • [SM-358] New visualization template and function block SMC_StartupAxisGroup for convenient and fast commissioning of axis groups.
  • [SM-1441] Better diagnosis of the axis group: new function block SMC_GroupReadPlanningStatistics.
New supported drive
Support for Yaskawa Sigma 7 series.
Major bug-fixes
  • [SM-1904] Too much vibration in specific movement sequence due to blending of lines with a very sharp angle (175°)
  • [SM-1895] Error SMC_AXIS_LIMIT_VIOLATION in specific movement sequence due to blending of lines with sharp angles (167°)
  • [SM-1925] Potential error SMC_AXIS_LIMIT_VIOLATION when blending between PTP movements and blending is limited by half of the element length
  • [SM-1814] Potiential problems with SDOs of EtherCAT slaves if many slaves are used
  • [SM-1971] SMC_ReadNCFile2 may get stuck (make no progress) if the g-code contains many expressions
  • [SM-1789] Long compile times in projects with a huge expanded library graph due to SoftMotion compile checks
  • [SM-1822] Missing DLL files (GAC assemblys) in package
46 minor bugs have been fixed.
07.02.2019
CODESYS SoftMotion 4.4.0.2 is a hotfix release.
It fixes the accident SM-1825, introduced in CODESYS SoftMotion 4.4.0.0, which may cause problems during installation of the SoftMotion package.
26.09.2018
CODESYS SoftMotion 4.4.0.1 is a hotfix release.
It fixes the accident SM-1814, introduced in CODESYS SoftMotion 4.4.0.0, which may cause problems during startup or acyclic communication of EtherCAT drives.
We recommend to update from CODESYS SoftMotion 4.4.0.0 to CODESYS SoftMotion 4.4.0.1.
07.09.2018
CODESYS SoftMotion 4.4.0.0 is a feature and bug-fix release.
Robotics Features
  • New movement type Path-invariant PTP: PTP movement whose path does not depend on the override and is not left in case of halt or interrupt
  • New function block SMC_GroupWait: Support for programmed waiting on the path
  • MoveLinear/MoveCircular: Reduction of jerk oscillations by adaptive planning intervals
  • MoveLinear/MoveCircular: Improved blending:
    • Optimized creation of blending-splines in case of asymmetric cut distances
    • In case of TransitionMode TMStartVelocity: Considering path geometry and dynamic axis limits at determination of blending points
  • Support for MoveLinear-/MoveCircular-movements with cartesian length 0 (or very small) and a change in orientation
  • Compatibility options: Enabling the user to deactivate recently released or upcoming improvements/bug-fixes that affect the resulting paths
CNC Features
  • Support for subprograms in G-code, including display of the callstack at interpretation- and interpolation-time
  • Support for expressions in G-code, including mathematical and boolean expressions as well as user-defined functions
  • Support for local variables in G-Code
Major bug-fixes
  • [SM-1511] CNC: Exception when using the method SetDelimiters of FB SMC_NCTokenizer
  • [SM-1519] Editors: Unhandled exception in automatic device import from fieldbus scan
  • [SM-1528] CNC: SMC_ToolRadiusCorr: possible error SMC_CNC_INTERNAL_ERROR
  • [SM-1538] Basic: Possible access violations during reconfiguration of EtherCAT master
  • [SM-1714] Basic/Robotics: Possible endless loop
  • [SM-1719] Basic: Unintended movement after quick stop
  • Accident [SM-1745] Robotics: SMC_GroupConvertPosition: conversions MCS -> ACS and WCS -> PCS not correct if MCS != WCS
  • [SM-1746] Robotics: CP: Using incorrect reference position for kinematic transformation
  • [SM-1778] Drivers: Parker SBC: Exception on RTE 64-BitCompatibility information
56 minor bugs have been fixed.
We recommend to update from CODESYS SoftMotion 4.3.2.0 (or earlier) to CODESYS SoftMotion 4.4.0.0.
29.08.2018
CODESYS SoftMotion 4.3.2.0 is a bug-fix release.
The following major bugs have been fixed:
- Accident SM-1645: Possible axis jump or error SMC_CP_NON_CONTINUABLE_STATE if orientation mode “Axis” is used with kinematics Kin_Scara3_Z. Introduced in version 4.3.0.0.
- Accident SM-1629: Missing initialization for Staubli kinematics. The Staubli Scara and 6-Axis robot kinematics did not work correctly due to an accident in version 4.3.0.0.
- Accident SM-1626: Possible memory overwrite during blending. Introduced in version 4.3.0.0.
- Accident SM-1543: Parker Compax 3: Invalid mapping of drive specific digital input object 16#6100:01 to in.dwDigitalInputs. Introduced in version 4.3.0.0
- SM-1458: EtherCAT drives using modular slaves (like EtherCAT_Stoeber_SI6_SC6) are not working with EtherCAT_Master versions >= 3.5.11.0.
- SM-1600: Robotics: too strict check of fSetJerk in AXIS_GROUP_REF_SM3.CheckSetValueLimits.
- SM-1575: SMC_ToolRadiusCorr: error SMC_CNC_INTERNAL_ERROR
- SM-1608: Possible oscillations of jerk and acceleration if dynamics are high and path planning interval is long.
- SM-1628: Possible FPU invalid operation exception on linux PLCs
Additionally, support for rotary axes with an axis range of more than 360° has been improved (SM-1531). It is now possible to command a linear or circular movement that crosses the period boundary of a rotary axis.
We recommend to update from CODESYS SoftMotion 4.3.1.0 (or earlier) to CODESYS SoftMotion 4.3.2.0.
06.03.2018
CODESYS SoftMotion 4.3.1.0 is a bug-fix release.
- Accident SM-1501: The forward transformation of Kin_Scara2_Z and Kin_Scara3_Z does not correctly consider dOffsetA1, dOffsetA2, and dOffsetA2.
- Accident SM-1503: Online change although the project has not changed.
- Bug SM-1506: Possible CNC access violation due to a problem in SMC_SetQueueCapacity.
- Bug SM-1508: Closing the CNC editor and immedatly closing the project may crash Codesys.
We recommend to update from SoftMotion 4.3.0.0 to SoftMotion 4.3.1.0.
16.11.2017
CODESYS SoftMotion 4.3.0.0 is a feature and bug-fix release.
New features of CNC function blocks:
- Support for tool-length compensation (G43)
- Support for rotated and scaled coordinate systems in the G-Code (G53 .. G56)
- Tool radius correction in arbitrary planes and 3D mode (G41, G42)
- Configurable tolerances for arc segments (G2, G3)
New Robotics features:
- Jogging of axis groups in product coordinate system (PCS) and tool coordinate system (TCS)
- Support for orientation mode Axis for Scara and 6-axis robot kinematics
New drivers:
- Panasonic MINAS A6B (EtherCAT)
- Stäubli robots via uniVal (EtherCAT)
About 50 bugs have been fixed.
26.10.2017
CODESYS SoftMotion 4.2.2.0 is a bug-fix release. It contains about 15 bug-fixes and features drivers for Bonfiglioli iBMD. 07.08.2017
This version contains changes to make it work with CODESYS V3.5 SP11 64-Bit. The motion libraries have not changed compared to version 4.2.1.1. 17.07.2017
This version fixes a major bug that can occur when reading G-Code files with the function block SMC_ReadNCFile. 15.05.2017
CODESYS SoftMotion 4.2.1.0 is a bug-fix release.
- Robotics: New Function Block MC_GroupSetPosition
- Robotics: Support for event-triggered bus tasks
- PLCopen conformance improvements: MC_PositionProfile, MC_VelocityProfile, MC_AccelerationProfile set axis state now in conformance with PLCopen MC Part 1
- Axis groups can now be used in simulation (with a compiler version >= 3.5.10.40)
- More than 20 bug fixes
04.05.2017
New Features:
- Support of MC_GroupSetOverride
- Support of MC_ GroupInterrupt and MC_ GroupContinue
- Robotics: New mode for CP orientation interpolation
Improvements:
- Robotics: Cartesian jogging of X/Y/Z and jogging the orientation axes in axis space.
- Robotics: New function block SMC_GroupTargetPosition
- Basic: Improved software limit reaction: brake before limit
About 60 Bugfixes.
06.04.2017
  14.12.2016
  17.11.2016
Reviews
Write Your Own Review
