CODESYS OPC DA Server SL
The CODESYS OPC Server V3 is based on the PLCHandler of 3S-Smart Software Solutions GmbH. This communication module permits a direct communication to all PLCs programmable with CODESYS.
(A 30 day demo license is available for testing.)
