CODESYS Control Win MC SL
CODESYS Control Win MC SL is an extension of CODESYS Control Win SL – an IEC 61131-3-compliant SoftPLC for PC-based industrial controllers running on Windows with soft real-time properties.
- Buy 4 for $114.00 each and save 5%
- Buy 10 for $109.20 each and save 9%
- Buy 25 for $102.00 each and save 15%
- Buy 50 for $97.20 each and save 19%
