CODESYS Control RTE SL (for Beckhoff CX)
3.5.19.0
2302000001
From $671.00
To $1,727.00
The product CODESYS Control RTE SL is a real-time software PLC for PC-based industrial controllers under Windows. The runtime system has its own real time kernel: deterministic behavior with jitter values in the µs region without additional hardware components or operating system extensions.
Interfaces
  • CODESYS OPC UA Server
The following CAN-PCI cards are supported:
  • Peak PCI: PCIe, MiniPCIe
  • Ixxat: SJA1000 (PCI card)
  • Automata: all PCI cards (1- and 2-channel)
Fieldbus support
  • CODESYS EtherCAT Master
  • CODESYS J1939
  • CODESYS PROFIBUS Master
  • CODESYS Sercos III Master
Product options
The product can be extended by the following chargeable options:
  • CODESYS SoftMotion SL
  • CODESYS WebVisu SL
  • CODESYS TargetVisu SL
CODESYS Development System V3.5.17.20 or higher
CODESYS Control V3.5.17.20
OS: Windows 8 / 10 / Embedded CPU: x86 (single core), x64 (multi core)
The following CAN-PCI cards are supported: - Peak PCI: PCIe, MiniPCIe (SJA1000-based) - Ixxat: SJA1000 (PCI card) - Automata: all PCI cards (1 and 2 channel)
The following Ethernet chipsets are supported: - Realtek - Intel
Sercos III Master: only 32bit supported
Version .zip with packed Setup.exe (32 and 64 bit) .zip with unpacked Setup (32 and 64 bit) Release Notes Release Date
3.5.19.0
08.03.2023
3.5.18.40
13.12.2022
3.5.18.30
06.10.2022
3.5.18.20
03.06.2022
3.5.18.0
Includes the following Security fixes: 2021-09, 2021-11, 2022-02, 2022-03, 2022-04, 2022-05, 2022-06, 2022-07
06.04.2022
3.5.17.50 - 28.10.2022
3.5.17.40 - 10.06.2022
3.5.17.20
02.11.2021
3.5.17.10
23.07.2021
3.5.17.0
28.04.2021
3.5.16.50
26.05.2021
3.5.16.40
28.01.2021
3.5.16.30
19.11.2020
3.5.16.20
3.5.16.10
3.5.16.0
07.04.2020
3.5.15.50
22.06.2020
3.5.15.40
3.5.15.30
3.5.15.20
3.5.15.10
19.09.2019
3.5.15.0
3.5.14.40 - 23.08.2019
3.5.14.30
3.5.14.20 - 18.04.2019
3.5.14.10
20.02.2019
3.5.14.0 17.12.2018
3.5.13.40
16.05.2019
3.5.13.30
18.01.2019
3.5.13.20
23.10.2018
3.5.13.10
23.08.2018
3.5.13.0
(Link to Advisory 2018-06)
Compatibility Information:
10.07.2018
3.5.12.70
13.11.2018
3.5.12.60
18.09.2018
3.5.12.50
17.07.2018
3.5.12.40
24.05.2018
3.5.12.30 27.04.2018
3.5.12.20
15.03.2018
3.5.12.10
For more details see:
26.02.2018
3.5.12.0 - 20.12.2017
3.5.11.60
20.04.2018
3.5.11.50
16.02.2018
3.5.11.40 - 17.11.2017
3.5.11.30 - 17.10.2017
3.5.11.20 - 21.09.2017
3.5.11.10 - 22.08.2017
3.5.11.0 - 14.07.2017
3.5.10.60 - 23.08.2017
3.5.10.50 - 17.07.2017
3.5.10.40 - 22.05.2017
3.5.10.20 - 16.03.2017
3.5.10.10 - 14.02.2017
3.5.10.0 - 14.12.2016
3.5.9.70 - 22.02.2017
3.5.9.60 - 20.01.2017
3.5.9.50 - 17.11.2016
3.5.9.40 - 02.11.2016
3.5.8.60 - 23.09.2016
