CODESYS Control for PLCnext MC SL
The CODESYS Control for PLCnext MC SL is an extension of the CODESYS Control for PLCnext SL, an adapted CODESYS Control runtime system for the Phoenix PLCnext controller AXC F 2152 or AXC F 1152.
4.7.0.0
2302000036
$66.00
CODESYS Control for PLCnext MC SL extends an existing Phoenix PLCnext controller AXC F 2152 or AXC F 1152, on which CODESYS Control for PLCnext SL is installed, to a multicore (MC) high-performance PLC. This can process its IEC application specifically on multiple CPU cores. The system is suitable for applications with soft demands on the real-time behavior.
Benefits
  • Extension of CODESYS Control for PLCnext SL for multicore support (all CPUs)
  • Extension of the CODESYS Development System for binding individual IEC applications to different CPU cores
  • Debugging of the multicore application within CODESYS
Fieldbus support
The fieldbuses of CODESYS Control for PLCnext SL are supported in single-core operation.
Product options
CODESYS Development System Version 3.5.16.20 or higher
CODESYS Control for PLCnext SL V4.0.0.0 or higher
  • Phoenix AXC F 2152
  • Phoenix AXC F 1152
Installation of CODESYS Control for PLCnext SL
Single Device License: The license can be used on the target device/PLC on which the CODESYS Runtime System is installed. Licenses are activated on a software-based license container (soft container), which is permanently connected to the controller.
25.01.2023
27.10.2022
01.09.2021
Important Note
Compatiblity information
Known limitations
16.06.2021
New independet release cycle Linux-based runtimes are now independent of the CODESYS Development System release cycle. Users profit from faster updates and bug fixes. Version number changed without compatibility break (runtime based on CODESYS Runtime Toolkit V3.5.x).
New features:
- Update to CODESYS Runtime Toolkit V3.5.16.40- Included linux packages for Edge Gateway - Add redundancy functionality (additional license required) - Support of PLCnext firmware 2021.0 - New configuration setting to change priority of device interrupts
Bug Fixes: - Fixed problems with Axioline Smart Elements - Fixed problems with retain memory - Fixed problems with thread priorities
04.03.2021
  • Support of AXC F 1152
  • Axioline driver: support of module scan
  • Axioline driver: support modules with complex parameterization (PDI read/write)
  • Various improvements and bug fixes
19.09.2019
New product
- Fully-adapted CODESYS runtime for the Phoenix PLCnext controller AXC F 2152
- Including licenses for CODESYS WebVisu, CODESYS OPC UA Server and selected CODESYS Fieldbuses
- Support of Axioline-I/O-System for analog and digital I/Os
30.07.2019
