CODESYS Control for PFC100 SL
$120.00
4.2.0.0
2302000019
  • Buy 4 for $114.00 each and save 5%
  • Buy 10 for $109.20 each and save 9%
  • Buy 25 for $102.00 each and save 15%
  • Buy 50 for $97.20 each and save 19%
This product allows users to program the WAGO PFC100 controller by using the free CODESYS Development System (V3).
Single Device License
CODESYS Control for PFC100 SL is a SoftPLC-based on CODESYS V3 for the WAGO PFC100 industrial PLC. After installation of the runtime environment, the PLC can be engineered with the CODESYS Development System (V3).
  • Download of the product “CODESYS Control for PFC100 SL” from the CODESYS Store (http://store.codesys.com)
  • Installation of CODESYS SoftPLC on a WAGO PFC100 device (http://www.wago.com)
Benefits
Interfaces
Fieldbus support
  • CODESYS CANopen Manager / Device (except 750-8202 / -8212)
  • CODESYS EtherCAT Master
  • CODESYS J1939
  • CODESYS Modbus Serial Master / Slave (only 750-8202 / -8212)
Product options
  • CODESYS KNX SL
  • CODESYS Redundancy SL
CODESYS Control V4.2.0.0 based on CODESYS Runtime Toolkit V3.5.17.10
All models of the WAGO PFC100 family
  • Minimum WAGO firmware version 02.07.07(10)
    • libm.so.6
    • libpthread.so.0
    • libdl.so.2
    • librt.so.1
    • libc.so.6
    • libgcc_s.so.1
    • libdbus-glib-1.so.2
    • libdbuskbuscommon.so.0
    • libffi.so.6
    • libglib-2.0.so.0
    • liblibloader.so.0
    • libnvram.so.0
    • libuio.so.0
    • liboms.so
    • libtypelabel.so
    • libdiagnostic.so
  • The software package does not support hardware-specific model variations.
A list of alternative support resources can be found at the support section of the CODESYS North America page.
01.09.2021
Important Note
Compatiblity information
Known limitations
16.06.2021
04.03.2021
04.12.2020
  • Support of WAGO firmware version 03.00.35(12)
23.08.2019
18.04.2019
20.02.2019
17.12.2018
18.01.2019
23.10.2018
10.07.2018
13.11.2018
24.05.2018
27.04.2018
26.02.2018
 - 20.12.2017
For more details see:
20.04.2018
16.02.2018
 - 21.09.2017
 - 22.08.2017
 - 17.07.2017
Reviews
Write Your Own Review
