$120.00
3.5.16.20
2302000026
  • Buy 4 for $114.00 each and save 5%
  • Buy 10 for $109.20 each and save 9%
  • Buy 25 for $102.00 each and save 15%
  • Buy 50 for $97.20 each and save 19%
This product allows users to program the Siemens SIMATIC IOT-Gateway by using the free CODESYS Development System (V3).
CODESYS Control for IOT2000 SL is a SoftPLC-based on CODESYS V3 for the Siemens SIMATIC IOT2000 family (for example, IOT2020, IOT2040). After installation of the runtime environment, the PLC acts as a full-featured CODESYS controller, which can be engineered with the CODESYS Development System (V3).
Benefits
  • Enhancement of the device to the full-featured CODESYS controller
  • Application creation with the free CODESYS Development System
  • Easy programming in IEC 61131-3 languages
  • For PLCs in building, factory, and process automation, as well as training
  • Efficient engineering with the add-on products of the CODESYS Professional Developer Edition
  • Extendable runtime system (for example, MQTT, MySQL, and MsSQL from the CODESYS Store)
Interfaces
Fieldbus support
  • CODESYS EtherCAT Master
Product options
  • CODESYS KNX SL
CODESYS Development System V3.5.16.20 or higher
CODESYS Control V3.5.16.20
Siemens SIMATIC IOT2020 and IOT2040
  • Siemens Yocto V2.1 and later
    • libm.so.6
    • libpthread.so.0
    • libdl.so.2
    • librt.so.1
    • libc.so.6
    • libgcc_s.so.1
Protocols for telecontrol technology are not supported.
Single device licensing
License activation via CODESYS Softcontainer (free of charge component of CODESYS Controls). Licensing via CODESYS Softcontainer is strictly linked to the selected hardware.
Note: Without a license the software runs in demo mode for two hours (manual restart is needed).
Provider
All Versions
Includes the following Security fixes: 2020-05
19.09.2019
23.08.2019
18.04.2019
20.02.2019
17.12.2018
18.01.2019
23.10.2018
10.07.2018
13.11.2018
27.04.2018
26.02.2018
 - 20.12.2017
For more details see:
20.04.2018
16.02.2018
 - 21.09.2017
 - 22.08.2017
 - 17.07.2017
Reviews
Write Your Own Review
